StarTech.com 8in DVI-I Male to DVI-D Female and HD15 VGA Female Wyse DVI Splitter Cable
Quicklinx: 9KZ8WS00 Mfr#: DVI92030202L
Length: 20.32cm
More than 50 in stock
£19.37 ex VAT
£23.24 inc VAT
Cost-effective replacement for your Wyse 920302-02L splitter cable - Connect a DVI-D and VGA monitor simultaneously to your Wyse terminal. The DVI92030202L Wyse DVI splitter cable features a male DVI-I connector which splits off to one female DVI-D cable as well as one female HD15 VGA cable, so you can simultaneously connect a DVI-D and a VGA display or projector to your Wyse terminal.
This high-quality dual monitor cable is a cost-effective replacement for your Wyse 920302-02L splitter cable.
StarTech.com 8in DVI-I to DVI-D and HD15 VGA Wyse DVI Splitter Cable - DVI splitter - 20.32 cm
DVI splitter
Double shielded
Length
20.32 cm
Connectors
DVI-I - male
Connectors (Second End)
HD-15 (VGA) - female , DVI-D - female
RoHS
DVI splitter
Double shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
20.32 cm
Connectors
24+5 pin combined DVI - male
15 pin HD D-Sub (HD-15) - female , 24+1 pin digital DVI - female
RoHS
Length: 20.32cm
Price Range Ex VAT: 0 - 50
