StarTech.com 8in 15 pin SATA Power Extension Cable
Quicklinx: 80HLWS00 Mfr#: SATAPOWEXT8
Length: 20.3cm
25 in stock
£5.40 ex VAT
£6.48 inc VAT
Extend SATA Power Connections by up to 8in. The SATAPOWEXT8 8-inch, 15-Pin SATA Power Extension Cable enables you to extend the reach between internal SATA power and drive connections by up to 8 inches. The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
StarTech.com 8in 15 pin SATA Power Extension Cable - power extension cable - 20.3 cm
Power extension cable
Length
20.3 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
15 pin Serial ATA power - female
1-year warranty
Length
20.3 cm
Connector
1-year warranty
Length: 20.3cm
Price Range Ex VAT: 0 - 50
