Your basket is empty
StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsink & TX3 Connector
Quicklinx: 4046WS00 Mfr#: FAN478
Type: Heatsink
More than 50 in stock
£9.34 ex VAT
£11.20 inc VAT
Standard delivery Delivered within 3-5 working days
Proper cooling systems are arguably the most important part of a fast-running, interruption-free computer. Without adequate cooling, workstations can overheat causing CPU slowdowns and system freezes translating into downtime. Fans like the FAN478 offer great cooling at a great price. Suited for Pentium 4 environments, this super-duty Socket 478 CPU cooler keeps your computer running at optimal temperatures. The closely spaced fins of the aluminum heatsink provide increased heat dissipation, more effective than normal heatsink/fan combos.
StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsink & TX3 Connector - processor cooler
Processor cooler
Compatibility
Socket 423, Socket 478
Heatsink Material
Aluminium
Fan Diameter
60 mm
Fan Height
10 mm
Noise Level
29 dB
Power Connector
3-pin plug
Ball bearing
Product Material
Aluminium
0.3 kg
2 years warranty
Processor cooler
Product Material
Aluminium
0.3 kg
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Heatsink Dimensions
82 mm x 70 mm x 39 mm
Fan Diameter
60 mm
Fan Height
10 mm
Noise Level
29 dB
Power Connector
3-pin plug
Ball bearing
StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsink & TX3 Connector Bundle deal on StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan with Heatsink & TX3 Connector
£25.66
saving £8.65
4046 StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink In Stock £3.49
Type: Heatsink
Price Range Ex VAT: 0 - 50
