Product
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector
Quicklinx: 76MGWS00 Mfr#: FANBOX2
Type: Case Fan
Hurry, only 1 left in stock!
£5.01 ex VAT
£6.01 inc VAT
The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status.
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ TX3 Connector - system fan kit
System fan kit
Fan Diameter
80 mm
Noise Level
34 dB
8 cm x 2.5 cm x 8 cm
75 g
2 years warranty
System fan kit
8 cm
2.5 cm
8 cm
75 g
Heatsink & Fan
Fan Diameter
80 mm
Noise Level
34 dB
Limited warranty - 2 years - carry-in
-10 °C
80 °C
76MG StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable In Stock £2.76
76MG StarTech.com Mounting PC Case Fan Screws - 50 Pack In Stock £1.39
Type: Case Fan
Price Range Ex VAT: 0 - 50
