StarTech.com 8 Port VGA Video Extender over Cat 5
Quicklinx: 7P2GWS00 Mfr#: ST1218T
£182.14 ex VAT
£218.56 inc VAT
This 8 Port transmitter unit is designed for use with StarTech.com's ST121 VGA Video over Cat 5 extension series. This convenient video distribution system simplifies implementing digital signage solutions by allowing a single VGA source to be broadcast to multiple displays at up to 492 ft. (150m) away.
Comprised of an 8 port VGA extender unit (this device - ST1218T) or a 4 port VGA extender unit (ST1214T) and one ST121R Receiver Unit per display as necessary, the VGA and Audio extension series can transmit a single VGA output and corresponding audio to four or eight displays/receivers over standard Cat 5 UTP cable.
For even more versatility, the VGA over Cat 5 Repeater (ST121EXT) can be used to increase the total VGA extension distance by an additional 492 ft., allowing the VGA signal to be broadcast at a total distance of 984 ft. from transmitter to receiver. Similarly, up to three repeater units can be used between the transmitter and receiver units allowing monitors to be connected between the two units, while still extending the total distance between the transmitter and receiver units.
StarTech.com 492 ft. (150 m) VGA Over Cat5 Extender - VGA Extender - 8 Port Repeater - Cat5 - Video Over Ethernet (ST1218T) - video extender
Video extender
External
Max Transfer Distance
150 m
P/N: ST121EXT, ST121R, SVA12M2NEUA, SVA12M5NA
Video extender
External
Wired
150 m
FCC, RoHS
External power adapter
7P2G StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.80
7P2G StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.80
7P2G StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.68
7P2G StarTech.com 8 Port VGA Video Extender over Cat 5 In Stock £182.14
7P2G StarTech.com 4 Port VGA Over CAT5 Video Extender - 450ft (150m) In Stock £109.08
7P2G StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.19
Price Range Ex VAT: 150 - 300
