Product
StarTech.com 8 Port VGA Video Extender over Cat 5 (UTPE Series)
Quicklinx: 82HWWS00 Mfr#: ST128UTPE
Extend and distribute your VGA video signal to up to eight remote displays using Cat 5 cabling. The ST128UTPE 8 Port VGA Video Extender over Cat 5 (UTPE Series) allows up to 9 (1 local and 8 remote) monitors to be connected to a single VGA source.
The video signal is carried to the remote monitors over standard 4 pair Category 5 and Category 6 UTP cable using RJ45 connectors and supports distances of up to 300m / 950ft.
At each remote monitor an STUTPRXL receiver is required. The receiver unit converts the signal from the UTP cable back into VGA video for the monitor.
StarTech.com 8 Port VGA Video Extender over Cat 5 (UTPE Series) - video splitter - 8 ports
Video splitter - 8 ports
20 cm x 8.4 cm x 3 cm
0.2 kg
1 year warranty
Enclosure Type
Desktop
Max Resolution
1024 x 768 @ 60 Hz
Status Indicators
1 x VGA output HD-15 , Display / video: 8 x RJ-45 , 1 x VGA input HD-15
External power adapter
FCC
20 cm
8.4 cm
3 cm
0.2 kg
1 year warranty
82HW StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.11
82HW StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.49
82HW StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £21.76
82HW StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £13.35
82HW StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
