Your basket is empty
StarTech.com 8 Port VGA over Cat5 Digital Signage Broadcaster with RS232 & Audio
Quicklinx: 76LVWS00 Mfr#: DS128
£199.03 ex VAT
£238.83 inc VAT
StarTech.com's DS Series Cat5 Digital Signage Broadcaster with RS232 Serial and Audio offers a comprehensive audio and video extension system, with the added benefit of serial control!
Compatible with virtually any VGA-capable PC or digital signage media player, the DS128 VGA splitter lets you deliver VGA video as well as the accompanying audio and serial control signals to the connected Cat5 VGA receivers (DSRXL - purchased separately), all through one Cat5 cable.
Comprised of this unit (DS128) and the corresponding receivers, the DS Series offers several unique features compared to the other VGA extenders, including the ability to extend RS-232 serial signals from the source to each display for controlling the displays as well as Java Client Management Software (DSNet Manager) that simplifies adjusting the settings for each receiver and display. The software can be controlled via an Ethernet port on a PC/media player or on a LAN (Local Area Network).
Ensuring not only a simple and cost-effective way to extend and control VGA video and the corresponding audio, the DS series (DS128 and DSRXL) also maintains exceptional, high quality video, up to 1600x1200 over a 100m connection. For further extension, you can daisy chain up to five receivers, for a maximum distance of 300m.
StarTech.com 8 Port Cat 5 VGA Digital Signage Broadcaster with RS232 & Audio - video/audio/serial extender
Video/audio/serial extender
Ports Qty
8
External
Cabling Type
10Base-T, 100Base-TX
Max Transfer Distance
300 m
1 year warranty
External
Ports Qty
8
Wired
Cabling Type
Max Resolution
1600 x 1200
300 m
Status Indicators
Link activity, port transmission speed, power, link OK
10 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x VGA - HD-15 female , 1 x VGA - HD-15 male , 1 x RS-232 - DB-9 male , 1 x RS-232 - DB-9 female , 2 x audio ( input ) - mini jack female
FCC, RoHS
External power adapter
1 year warranty
Service & Support Details
Limited warranty - 1 year
0 - 90%
76LV StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.75
76LV StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £11.90
76LV StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.75
76LV StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.55
76LV StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £17.96
76LV StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £9.38
76LV StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.98
Type: Media Converter
Price Range Ex VAT: 150 - 300
