The ST128UTPEA is the 8 Port Extender Transmitter unit utilized by StarTech.com UTPEA VGA and Audio over Cat 5 extension series. This convenient video distribution system simplifies implementing digital signage solutions by allowing a single VGA source and corresponding audio to be broadcast to multiple displays at up to 300m (950ft) away.
Comprised of a 4 port VGA & Audio extender unit (ST124UTPEA) or this 8 port VGA & Audio extender unit and one STUTPEALR Receiver Unit or STUTPRXWLA wall-plate receiver (see accessories) per display as necessary, the VGA and Audio extension series can transmit a single VGA output and corresponding audio to four or eight displays/receivers over standard Cat 5 UTP cable.
For even more versatility, the VGA & Audio over Cat 5 Line Splitter (STUTPEA4X) can be used to multiply the number of potential displays by four - allowing the VGA signal and accompanying audio to be broadcast to up to 16 or 32 VGA displays.
- StarTech.com 8 Port VGA and Audio over Cat 5 Video Extender - video/audio extender
- Video/audio extender
- Ports Qty
- 8
- Form Factor
- External
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 300 m
- 22 cm x 11.9 cm x 4.1 cm
- 0.7 kg
- 2-year warranty
- Designed For
- P/N: STUTPEALR, SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Ports Qty
- 8
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1200
- 300 m
- 1 x VGA (input) - HD-15 male , 1 x VGA (output) - HD-15 female , 8 x display / video - output - RJ-45 female , 1 x audio (input) - mini jack female
- FCC, RoHS
- Power Device
- External power adapter
- 22 cm
- 11.9 cm
- 4.1 cm
- 0.7 kg
- Limited warranty - 2 years
- Designed For
