Your basket is empty
StarTech.com 8 Port VGA and Audio over Cat 5 Video Extender
Quicklinx: 7B7MWS00 Mfr#: ST128UTPEA
The ST128UTPEA is the 8 Port Extender Transmitter unit utilized by StarTech.com UTPEA VGA and Audio over Cat 5 extension series. This convenient video distribution system simplifies implementing digital signage solutions by allowing a single VGA source and corresponding audio to be broadcast to multiple displays at up to 300m (950ft) away.
Comprised of a 4 port VGA & Audio extender unit (ST124UTPEA) or this 8 port VGA & Audio extender unit and one STUTPEALR Receiver Unit or STUTPRXWLA wall-plate receiver (see accessories) per display as necessary, the VGA and Audio extension series can transmit a single VGA output and corresponding audio to four or eight displays/receivers over standard Cat 5 UTP cable.
For even more versatility, the VGA & Audio over Cat 5 Line Splitter (STUTPEA4X) can be used to multiply the number of potential displays by four - allowing the VGA signal and accompanying audio to be broadcast to up to 16 or 32 VGA displays.
StarTech.com 8 Port VGA and Audio over Cat 5 Video Extender - video/audio extender
Video/audio extender
Ports Qty
8
External
Max Transfer Distance
300 m
22 cm x 11.9 cm x 4.1 cm
0.7 kg
2 years warranty
External
Ports Qty
8
Wired
Max Resolution
1920 x 1200
300 m
1 x VGA (input) - HD-15 male , 1 x VGA (output) - HD-15 female , 8 x display / video - output - RJ-45 female , 1 x audio (input) - mini jack female
FCC, RoHS
External power adapter
22 cm
11.9 cm
4.1 cm
0.7 kg
7B7M StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.73
7B7M StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £13.70
7B7M StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.73
7B7M StarTech.com 50 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £11.49
7B7M StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £21.76
7B7M StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £9.91
7B7M StarTech.com 75 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £13.09
