Your basket is empty
StarTech.com 8 Port USB VGA IP KVM Switch with Virtual Media
Quicklinx: 8G4PWS00 Mfr#: SV841DUSBI
Control up to 8 USB VGA computers remotely over an IP network or the Internet. The SV841DUSBI 8-Port USB VGA IP KVM Switch with Virtual Media enables secure local and remote control of up to 8 computers, over a LAN or the Internet. With 2 additional USB ports for peripheral sharing (USB storage, CD ROM, etc.), the KVM Switch offers a convenient solution for file transfers and disk emulation for remote applications and OS installs.
The IP KVM Switch enables BIOS level control and full boot process interaction, and includes several security features (SSH, SSL, RADIUS and a configurable firewall) to keep your network safe.
This highly versatile KVM can interact with virtually any device that uses an RS232 serial terminal (routers, switches, PDUs, etc.), using the RPORT Serial Remote Control Module (sold separately), and features a 1U rack-mountable metal chassis that makes installation into a rack easy with the 1110EXTRACK Rackmount Brackets.
StarTech.com 8 Port USB VGA IP KVM Switch with Virtual Media - KVM switch - 8 ports
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
Remote Management Protocol
SNMP, HTTP, HTTPS, VNC, SSH
On-Screen Display, DHCP support, Syslog support
AC 120/230 V
20 cm x 18.7 cm x 4.4 cm
1.26 kg
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Authentication Method
Secure Shell (SSH), RADIUS
Max Resolution
1920 x 1440 @ 85 Hz
Status Indicators
Port status
8 x KVM HD-15
External power adapter
AC 120/230 V
4 x keyboard / mouse / video cable - 3 m , 4 x keyboard / mouse / video cable - 1.8 m
FCC, RoHS
20 cm
18.7 cm
4.4 cm
1.26 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Humidity Range Storage
0 - 80%
8G4P StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £9.68
8G4P StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £6.69
