StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub
Quicklinx: 76MMWS00 Mfr#: ICUSB2328
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£133.49 ex VAT
£160.18 inc VAT
Got more serial peripherals than you do ports? Don't sweat it, StarTech.com has the solution to your problem with the ICUSB2328. It equips your system with eight RS-232 serial ports while taking up only one USB port! Connecting devices like serial modems, GPS receivers, serial printers, and PDAs has never been easier. Perfect for laptop users, the ICUSB2328 is lightweight and compact, so you can take it with you when you're on the go. As well, the unit is fully plug and play compatible, allowing you the flexibility of hot swapping your serial devices without rebooting.
StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 8
RS-232
Data Transfer Rate
115 Kbps
FT232RL - FTDI
Linux, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Apple MacOS X 10.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Serial adapter
External
USB 2.0
Ports
RS-232 x 8
Wired
RS-232
Data Transfer Rate
115 Kbps
Processor / Memory
FT232RL - FTDI
8 x RS-232 - 9 pin D-Sub (DB-9) - male (on cable) , 1 x RS-232 - 62 pin D-Sub (DB-62) - female
1 x USB-A to USB-B cable (external) - 1.83 m , 1 x breakout cable (external)
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
55 °C
5 - 95%
76MM StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
76MM StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
76MM StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
76MM StarTech.com 15 ft Transparent USB 2.0 Cable - A to B In Stock £4.72
76MM StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.44
76MM StarTech.com 10 ft Transparent USB 2.0 Cable - A to B In Stock £1.89
76MM StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
76MM StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.61
76MM StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £20.79
76MM StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £62.04
76MM StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £34.70
76MM StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub In Stock £133.49
76MM StarTech.com 4 Port USB to Serial Hub In Stock £52.67
Price Range Ex VAT: 100 - 150
