Got more serial peripherals than you do ports? Don't sweat it, StarTech.com has the solution to your problem with the ICUSB2328. It equips your system with eight RS-232 serial ports while taking up only one USB port! Connecting devices like serial modems, GPS receivers, serial printers, and PDAs has never been easier. Perfect for laptop users, the ICUSB2328 is lightweight and compact, so you can take it with you when you're on the go. As well, the unit is fully plug and play compatible, allowing you the flexibility of hot swapping your serial devices without rebooting.
- StarTech.com USB to Serial Adapter Hub - 8 Port - DB9 (9-pin) - USB Serial - FTDI USB to RS232 Adapter - USB Serial (ICUSB2328) - serial adapter - USB 2.0 - RS-232 x 8
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 8
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 115 Kbps
- Processor
- FTDI FT232RL FT232RL
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Apple MacOS X 10.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- RS-232
- 115 Kbps
Processor / Memory
- Processor
- 8 x RS-232 - 9 pin D-Sub (DB-9) - male (on cable) , 1 x RS-232 - 62 pin D-Sub (DB-62) - female
- Cables Included
- 1 x USB-A to USB-B cable (external) - 1.83 m , 1 x breakout cable (external)
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.84 |
StarTech.com 6ft Straight Through Serial Cable - DB9 M/F | In Stock | £3.53 |
StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M | In Stock | £3.83 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £21.31 |
StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention | In Stock | £62.71 |
StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention | In Stock | £35.13 |
StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub | In Stock | £134.94 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £53.33 |
