StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub
Quicklinx: 76MMWS00 Mfr#: ICUSB2328
Got more serial peripherals than you do ports? Don't sweat it, StarTech.com has the solution to your problem with the ICUSB2328. It equips your system with eight RS-232 serial ports while taking up only one USB port! Connecting devices like serial modems, GPS receivers, serial printers, and PDAs has never been easier. Perfect for laptop users, the ICUSB2328 is lightweight and compact, so you can take it with you when you're on the go. As well, the unit is fully plug and play compatible, allowing you the flexibility of hot swapping your serial devices without rebooting.
StarTech.com USB to Serial Adapter Hub - 8 Port - DB9 (9-pin) - USB Serial - FTDI USB to RS232 Adapter - USB Serial (ICUSB2328) - serial adapter - USB 2.0 - RS-232 x 8
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 8
RS-232
Data Transfer Rate
115 Kbps
FTDI FT232RL
Microsoft Windows CE 4.2, Microsoft Windows CE 5.0, Microsoft Windows CE 6.0, Microsoft Windows XP Embedded, Microsoft Windows 98 Second Edition, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows 11, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux Kernel 3.0 or later, Linux LTS versions only
Serial adapter
External
USB 2.0
Ports
RS-232 x 8
Wired
RS-232
Data Transfer Rate
115 Kbps
Processor / Memory
FTDI FT232RL
8 x RS-232 - 9 pin D-Sub (DB-9) - male (on cable) , 1 x RS-232 - 62 pin D-Sub (DB-62) - female
1 x USB-A to USB-B cable (external) - 1.83 m , 1 x breakout cable (external)
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
55 °C
5 - 95%
76MM StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.73
76MM StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.73
76MM StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £13.22
76MM StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
76MM StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.44
76MM StarTech.com USB to RS232 Serial Adapter In Stock £16.28
76MM StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
76MM StarTech.com 4 Port USB to Serial Hub In Stock £78.51
76MM StarTech.com 4-Port USB to Serial Adapter In Stock £212.24
76MM StarTech.com 8-Port USB to Serial Adapter In Stock £340.65
