Got more serial peripherals than you do ports? Don't sweat it, StarTech.com has the solution to your problem with the ICUSB2328. It equips your system with eight RS-232 serial ports while taking up only one USB port! Connecting devices like serial modems, GPS receivers, serial printers, and PDAs has never been easier. Perfect for laptop users, the ICUSB2328 is lightweight and compact, so you can take it with you when you're on the go. As well, the unit is fully plug and play compatible, allowing you the flexibility of hot swapping your serial devices without rebooting.
- StarTech.com USB to Serial Adapter Hub - 8 Port - DB9 (9-pin) - USB Serial - FTDI USB to RS232 Adapter - USB Serial (ICUSB2328) - serial adapter - USB 2.0 - RS-232 x 8
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 8
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 115 Kbps
- Processor
- FTDI FT232RL
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
- Limited lifetime warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- RS-232
- 115 Kbps
Processor / Memory
- Processor
- FTDI FT232RL
- 8 x RS-232 - 9 pin D-Sub (DB-9) - male (on cable) , 1 x RS-232 - 62 pin D-Sub (DB-62) - female
- Cables Included
- 1 x USB-A to USB-B cable (external) - 1.83 m , 1 x breakout cable (external)
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.76 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £33.28 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £15.32 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.35 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.05 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.20 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £79.35 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £244.59 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £392.69 |
