Add 8 DIN Rail-mountable RS232 Serial ports to any system through USB. The ICUSB2328I Industrial 8-Port USB to Serial Hub with DIN Rail Clips converts a single USB port into eight RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this 8 port USB to RS232 Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the USB serial hub ports.
- StarTech.com 8 Port USB to Serial RS232 Adapter - Wall Mount - Din Rail - COM Port Retention - FTDI USB to DB9 RS232 Hub (ICUSB2328I) - serial adapter - USB 2.0 - RS-232 x 8
- Serial adapter
- Form Factor
- DIN rail mountable
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 8
- 9.72 cm x 17.35 cm x 4.32 cm
- 950 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Processor
- FTDI FT232RL
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
- 2-year warranty
- Serial adapter
- Form Factor
- USB 2.0
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- Status Indicators
- Port status, transmit, receive
- USB powered, wall mountable, DIN rail mountable
Processor / Memory
- Processor
- FTDI FT232RL
- 8 x RS-232 - 9 pin D-Sub (DB-9) - male
- Cables Included
- 1 x USB-A to USB-B cable (external) - 1.83 m
- Mounting Kit
- Included
- FCC, RoHS
- Black
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- OS Required
- 9.72 cm
- 17.35 cm
- 4.32 cm
- 950 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.40 |
StarTech.com 6ft Straight Through Serial Cable - DB9 M/F | In Stock | £3.85 |
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £16.79 |
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 1 - M/F | In Stock | £6.56 |
StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub | In Stock | £155.19 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £17.44 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £135.79 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F | In Stock | £4.30 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £12.50 |
StarTech.com 16-Port USB-Serial Adapter Hub | In Stock | £352.65 |
StarTech.com 8 Port USB-Serial Adapter Hub | In Stock | £196.29 |
