StarTech.com 8 Port USB-Serial Adapter Hub
Quicklinx: CGGQWS00 Mfr#: ICUSB23208FD
Wired / Wireless: Wired
Protocol: RS-232
Compatibility: Mac, PC
Type: Serial adapter
12 in stock
£168.85 ex VAT
£202.62 inc VAT
Convert a single USB port into eight serial ports, and connect multiple hubs together for a scalable solution. This 8-port USB-to-serial adapter hub provides an easy and cost-efficient way to add RS232 serial capability to your industrial setting. It features a sturdy, rack-mountable chassis, and supports daisy chaining, so you can connect multiple hubs together to increase your serial device port count.
This rack-mountable USB serial hub (FTDI) lets you add eight serial ports (RS232), with full control from your desktop or laptop computer system using a single USB port. The daisy-chain function gives you a cost-effective and scalable way to increase your serial port count and expand as your needs grow, without investing in a more expensive serial hub.
Providing full control of your serial components from a single device, the USB serial hub is ideal for a multitude of applications including industrial automation, self-serve automated kiosks, and monitoring of cameras and security systems.
The hub features COM port retention, which retains the assigned serial COM port values. This ensures that the same values are automatically re-assigned to the port provided by the adapter, in the event it is disconnected and re-connected to the host computer.
The hub features a reliable FTDI USB-to-serial chipset, which provides easy installation into a broad range of operating systems.
With its all-metal chassis, this rugged, rack-mountable hub fits into standard 19-inch server storage racks to provide an efficient industrial serial solution. It supports an extended operating temperature range of -40°C to 85°C (-40°F to 185°F), ensuring reliable performance even in the harshest environments. The USB-serial hub includes both an AC adapter and terminal block power, providing versatile power options.
StarTech.com 8 Port USB to Serial Adapter Hub - USB to RS232 Daisy Chain - serial adapter
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 8
12 cm x 43 cm x 4.5 cm
1.4 kg
RS-232
AC 120/230 V
Linux, Microsoft Windows Server 2012, Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11
Serial adapter
External
USB 2.0
Ports
RS-232 x 8
Wired
RS-232
Status Indicators
Status
8 x RS-232 - 9 pin D-Sub (DB-9) (male) , 1 x USB - 4 pin USB Type B
2 rack mount brackets, 4 x nuts, rack mounting screws, DIN rail mounting screws, 2 DIN rail mounting brackets, 4 washers, terminal block plug, power adapter
1 x USB cable (external) - 90 cm
FCC, RoHS
AC 120/230 V
36 Watt
Software Included
Drivers & Utilities
12 cm
43 cm
4.5 cm
1.4 kg
-40 °C
85 °C
20 - 80% (non-condensing)
CGGQ StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £62.04
CGGQ StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub In Stock £133.49
CGGQ StarTech.com 16-Port USB-Serial Adapter Hub In Stock £303.34
CGGQ StarTech.com 8 Port USB-Serial Adapter Hub In Stock £168.85
Protocol: RS-232
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 150 - 300
