StarTech.com 8 Port USB KVM Switch Module for 1UCABCONS/17/19
Quicklinx: 8K08WS00 Mfr#: CAB831HDU
Type: KVM switch
Connectivity: KVM
Ports: 8
£243.94 ex VAT
£292.72 inc VAT
Enhance your StarTech.com LCD console by adding control for eight USB computers, or use with a separate USB keyboard and mouse with VGA display. This 8-port KVM module works with the StarTech.com series of rack-mounted LCD consoles, enabling you to control eight servers from one location. You can upgrade a single port LCD console or replace a faulty console.
With independent VGA and USB keyboard and mouse ports, you can also use this switch as a standalone KVM, creating a discreet rack-mountable KVM solution.
By adding this KVM module to your rack mount LCD console you can control eight individual computers or servers from a centralized location.
Because the KVM module works with your existing LCD console, you can ensure simple integration into your server room setup. To ensure compatibility this KVM module supports any operating system has been extensively tested in Windows, Mac and Linux environments.
You can also connect to USB servers using StarTech.com's convenient line of 2-in-1 USB KVM cables. The cables come in variety of lengths your specific requirements.
StarTech.com 8-port USB KVM Module for Rack-Mount LCD Consoles with additional USB and VGA Console (CAB831HDU) - KVM switch - 8 ports - rack-mountable
KVM switch - 8 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display, rugged
AC 120/230 V
43.6 cm x 18 cm x 4.5 cm
1.4 kg
3-year warranty
P/N: RKCONS1908K, RKCONS1916K, SVECONUS10, SVECONUS15, SVECONUS6
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440 @ 60 Hz
Status Indicators
Link/activity
8 x KVM HD-15 , 1 x VGA HD-15 , Keyboard / mouse: 2 x USB 2.0 - 4 pin USB Type A , Keyboard / video / mouse (KVM): 1 x 36 PIN Centronics
External power adapter
AC 120/230 V
Rack Mounting Kit
Included
DDC-2B, FCC, RoHS
43.6 cm
18 cm
4.5 cm
1.4 kg
Limited warranty - 3 years
5 °C
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
8K08 StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £6.74
8K08 StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.75
8K08 StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £14.24
8K08 StarTech.com 8 Port USB KVM Switch Module for 1UCABCONS/17/19 In Stock £243.94
Type: KVM switch
Connectivity: KVM
Ports: 8
Price Range Ex VAT: 150 - 300
