StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch
Quicklinx: 98G1WS00 Mfr#: IES81000POE
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
Hurry, only 2 left in stock!
£216.29 ex VAT
£259.54 inc VAT
Connect power and Gigabit Ethernet data to 8 PoE-enabled devices, with 30W per-port output - Wall Mountable. The IES81000POE 8-Port Gigabit Power over Ethernet Switch lets you connect Gigabit Ethernet and power to up to eight PoE-enabled devices, or a mixture of PoE and non-PoE components.
Giving you the freedom to place your equipment in locations where power outlets are not available, this PoE+ switch complies with IEEE 802.3af and 802.3at standards and supplies up to 30 W per port, with a total power budget of 120 W.
A true unmanaged switching solution, the 8 PSE (Power Sourcing Equipment) ports sense whether the connected devices are PoE-ready or require data connectivity only, and also auto-negotiate between 10/100/1000 Mbps network speed and duplex.
The Gigabit Ethernet switch features a sturdy, wall-mountable metal enclosure for durability, and front panel LEDs for quick indication of connection speed and status.
StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch - Wall Mountable - PoE Network Switch (IES81000POE) - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, 128KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
AC 120/230 V
18.8 cm x 11.9 cm x 3.8 cm
750 g
North America, United Kingdom, Europe
P/N: POEEXT1GAT, POEEXT2GAT
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
Status Indicators
Port transmission speed, power, active, PoE
8 x 1000Base-T RJ-45 PoE+ - 30 W
External power adapter
AC 120/230 V
120 Watt
FCC, RoHS
18.8 cm
11.9 cm
3.8 cm
750 g
55 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
90 °C
98G1 StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 Power over Ethernet ports In Stock £165.68
98G1 StarTech.com 10 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.25
98G1 StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch In Stock £216.29
98G1 StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet In Stock £102.51
Ports: 8
Managed: No
POE: PoE+
Price Range Ex VAT: 150 - 300
