Add four RS232 and four RS422/485 serial ports to your standard or low profile system through a PCIe slot. The PEX8S232485 8-Port PCIe Serial Combo Card lets you add four RS232 and four RS422 / RS485 serial ports to your PC through a single PCI Express expansion slot.
This multi-port serial card is a single card solution that offers compatibility with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes at data rates up to 460Kbps.
To fit most standard computer cases, the card ships with a standard profile bracket installed and includes a low-profile / half-height bracket for adapting to slimline or small form factor systems. Plus, the included breakout cable helps to avoid cluttered connections.
- StarTech.com 8 Port PCIe RS232/422/485 Serial Card - 4x RS232 4x RS422/RS485 - serial adapter - PCIe
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Data Link Protocol
- RS-232, RS-422, RS-485
- Data Transfer Rate
- 460.8 Kbps
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Connectivity Technology
- Wired
- 460.8 Kbps
- 8 - 9 pin D-Sub (DB-9) (on cable)
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- 0 °C
- 100 °C
- 20 - 80%
