Your basket is empty
StarTech.com 8 Port PCI Express (PCIe) RS-232/422/485 Serial Card - 4 x RS232 4 x RS422 / RS485
Quicklinx: 920MWS00 Mfr#: PEX8S232485
  • Windows 8 (32/64 bits)
Add four RS232 and four RS422/485 serial ports to your standard or low profile system through a PCIe slot. The PEX8S232485 8-Port PCIe Serial Combo Card lets you add four RS232 and four RS422 / RS485 serial ports to your PC through a single PCI Express expansion slot.
This multi-port serial card is a single card solution that offers compatibility with nearly any serial communication protocol, supporting RS-232, RS-422, RS-485 2-wire or RS-485 4-wire operating modes at data rates up to 460Kbps.
To fit most standard computer cases, the card ships with a standard profile bracket installed and includes a low-profile / half-height bracket for adapting to slimline or small form factor systems. Plus, the included breakout cable helps to avoid cluttered connections.
StarTech.com 8 Port PCIe RS232/422/485 Serial Card - 4x RS232 4x RS422/RS485 - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Data Transfer Rate
460.8 Kbps
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Serial adapter
Plug-in card
PCI Express x1
Wired
Data Transfer Rate
460.8 Kbps
8 - 9 pin D-Sub (DB-9) (on cable)
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
100 °C
20 - 80%
920M StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.28
920M StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.52
