This PCI Express based serial adapter card allows you to turn a PCI Express slot into eight RS232 (DB9) serial connections. The adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards. The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, as well as MAC OS 10.4 and above.
- StarTech.com Replaced by PEX8S1050 - 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART (PEX8S952) - serial adapter - PCIe - RS-232 x 8
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports
- RS-232 x 8
- 2 cm x 9 cm x 6.5 cm
- 58 g
- Data Link Protocol
- RS-232
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows 2000 / ME / XP, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- RS-232
- Software flow control, hardware flow control
- 8 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express x1
- FCC, RoHS
- OS Required
- 2 cm
- 9 cm
- 6.5 cm
- 58 g
- Limited warranty - lifetime
- Designed For
