Split an HDMI audio and video signal to eight displays simultaneously.
The ST128HDMI2 8-Port High Speed HDMI Splitter (rack mountable) lets you share a single HDMI audio-video source with up to 8 HDMI or DVI-D displays without sacrificing image or sound quality.
Supporting True HD 1080p video resolutions, the HDMI splitter acts as a distribution amplifier that enables you to situate your HDMI-capable displays up to 50ft (15m) away from the splitter, and features 3.5mm audio connections, giving you the option of sending your accompanying audio signal through the HDMI cable, or through a separate channel.
A perfect addition to virtually any application requiring the high quality video, the ST128HDMI2 HDMI splitter is easy to install as a standalone or rack-mounted device using the included brackets and provides flawless, distortion-free digital video.
- StarTech.com 8 Port HDMI Splitter - Mounting Brackets - HDMI Multi Port - HDMI Hub - HDMI Audio Splitter - HDMI Splitter Box (ST128HDMI2) - video/audio splitter - 8 ports - rack-mountable
- Video/audio splitter - 8 ports - cascadable
- Enclosure Type
- Rack-mountable
- Subtype
- HDMI
- Ports
- 8 x HDMI
- Power
- AC 120/230 V
- 18.5 cm 4.4 cm
- 3.5 kg
- Black
- 3-year warranty
- Designed For
- P/N: ST121SHD50, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Rack-mountable
- Subtype
- HDMI
- Ports
- 8 x HDMI
- Max Units In A Stack
- 3
- Max Resolution
- 1080p
- HDTV support
- Status Indicators
- Port status, power
- 8 x HDMI , 1 x HDMI , 1 x audio input mini-jack , 8 x audio output mini-jack
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 10.2 Watt
- Black
- Rack Mounting Kit
- Included
- FCC, RoHS
- 18.5 cm
- 4.4 cm
- 3.5 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.29 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.82 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.16 |
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £103.47 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.39 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.00 |
StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £96.70 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
