Brand
StarTech.com 8-Port GbE Switch - Managed
Quicklinx: CWBBWS00 Mfr#: IES81GW
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
Hurry, only 2 left in stock!
£140.93 ex VAT
£169.11 inc VAT
Connect up to 8 different GbE devices using this IP30 industrial Ethernet switch with intelligent Layer 2 management. Easily deploy or scale your network with this Gigabit Ethernet switch, adding eight copper Gigabit Ethernet connections. This IP30 industrial network switch provides intelligent Layer 2 management. Its rugged, compact design and wall-mount option with front access make it ideal for demanding applications, even where space is limited.
This Gigabit Ethernet switch lets you expand your network by connecting up to eight RJ45 devices. The 8-Port switch enables up to eight users to share files and devices, such as printers and scanners, over a LAN connection, by enhancing your existing network capacity with additional ports.
With its compact design, you can wall-mount the Gigabit switch to provide convenient front access to ports and indicators. It's ideal for a wide range of applications, including tight installation areas with significant electromagnetic interference, such as control cabinets and panels. The network switch is also DIN-rail mountable.
The scalable switch delivers efficient and stable performance, with Layer 2 management capabilities. This lets you control packet traffic on a busy network, and customize your settings to achieve optimal network performance, offering improved efficiency and reliability.
This rugged network switch features an IP30-rated metal housing and extended temperature range of -40°C to 75°C, which makes it ideal for a wide range of operating conditions. The sturdy metal enclosure offers durability, even in harsh industrial environments.
With support for 10/100/1000Mbps transfer speeds, this managed switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation. This lets you connect your network devices quickly and easily, with little to no configuration required.
To help prevent any unnecessary downtime, the switch features redundant 12-58V DC terminal block power inputs, which ensures seamless operation in the event of power dips or failures.
StarTech.com Industrial 8 Port Gigabit Ethernet Switch - Hardened Compact Layer/L2 Managed Network LAN/RJ45 Switch Mountable -40C to +75C (IES81GW) - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Data transfer rate: 2 Gbps
Jumbo Frame Support
9KB
Routing Protocol
IGMP, MLD
Remote Management Protocol
HTTP
Layer 2 switching, IPv6 support, full duplex mode, wall mountable, Trivial File Transfer Protocol (TFTP) support, tagged VLAN, 6KV ESD Protector, 802.1x authentication, Internet Control Message Protocol (ICMP), 6KV EFT protector
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
14.8 cm x 13.4 cm x 2.5 cm
496 g
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Jumbo Frame Support
9KB
Routing Protocol
IGMP, MLD
HTTP
Status Indicators
8 x 1000Base-TX RJ-45 , 1 x terminal block
4 magnets, DIN-rail mounting kit, 4 x screws, attaching pins, locking pins, 4 washers, 8 RJ45 dust caps
MTBF
>100,000 hours
FCC, RoHS, WEEE, IP30, RCM
14.8 cm
13.4 cm
2.5 cm
496 g
-40 °C
75 °C
5 - 95% (non-condensing)
CWBB StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £11.70
CWBB StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch In Stock £216.10
CWBB StarTech.com 8-Port GbE Switch - Managed In Stock £140.93
CWBB StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £344.22
CWBB StarTech.com DC Power Adapter - 12V, 2A In Stock £13.40
CWBB StarTech.com DC Power Adapter - 12V, 5A In Stock £33.16
Ports: 8
Managed: Yes
Stock Status: In stock
