The SV831DUSBUK 8-port rack mount USB KVM switch kit offers a well-appointed KVM switch that includes all of the cables and accessories required to connect to 8 servers or PCs right out of the box, making setup convenient and simple.
The USB KVM delivers a dependable computer management tool that allows you to control up to 8 USB-connected computers from a single keyboard, mouse and display, providing maximum control through hotkey command-based switching or front panel push-buttons, with the added configurability and convenience of an On-Screen Display.
A suitable addition to server room operations, the 8-port switch can be rackmounted into 1U of cabinet space and can be cascaded with multiple KVM switches to enable control of up to 64 computers from this single switch.
- StarTech.com 8 Port 1U Rack Mount USB KVM Switch Kit with OSD and Cables - KVM switch - 8 ports - rack-mountable
- KVM switch - 8 ports - cascadable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- 43.8 cm x 18 cm x 4.5 cm
- 2.9 kg
- 3 years warranty
- Designed For
- P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK12OD, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK960CP, RKQMCAB12, RKWOODCAB12
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- Status Indicators
- Port status, power
- 8 x KVM HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
- Power Device
- External power adapter
- Cables Included
- 8 x keyboard / mouse / video cable
- Rack Mounting Kit
- Included
- 43.8 cm
- 18 cm
- 4.5 cm
- 2.9 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- Designed For
StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £6.66 |
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.64 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £14.08 |
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £31.54 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £32.89 |
StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £288.86 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £254.74 |
StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.64 |
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable | In Stock | £6.66 |
