Product
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables
Quicklinx: 7P3FWS00 Mfr#: SV831DUSBUK
Type: KVM switch
Connectivity: KVM
Ports: 8
21 in stock
£254.74 ex VAT
£305.68 inc VAT
The SV831DUSBUK 8-port rack mount USB KVM switch kit offers a well-appointed KVM switch that includes all of the cables and accessories required to connect to 8 servers or PCs right out of the box, making setup convenient and simple.
The USB KVM delivers a dependable computer management tool that allows you to control up to 8 USB-connected computers from a single keyboard, mouse and display, providing maximum control through hotkey command-based switching or front panel push-buttons, with the added configurability and convenience of an On-Screen Display.
A suitable addition to server room operations, the 8-port switch can be rackmounted into 1U of cabinet space and can be cascaded with multiple KVM switches to enable control of up to 64 computers from this single switch.
StarTech.com 8 Port 1U Rack Mount USB KVM Switch Kit with OSD and Cables - KVM switch - 8 ports - rack-mountable
KVM switch - 8 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
43.8 cm x 18 cm x 4.5 cm
2.9 kg
3 years warranty
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK12OD, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK960CP, RKQMCAB12, RKWOODCAB12
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
Status Indicators
Port status, power
8 x KVM HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
External power adapter
8 x keyboard / mouse / video cable
Rack Mounting Kit
Included
43.8 cm
18 cm
4.5 cm
2.9 kg
Limited warranty - 3 years
5 °C
7P3F StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £6.66
7P3F StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
7P3F StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £14.08
7P3F StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £31.54
7P3F StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £32.89
7P3F StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft In Stock £288.86
7P3F StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £254.74
7P3F StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
7P3F StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £6.66
Type: KVM switch
Connectivity: KVM
Ports: 8
Price Range Ex VAT: 150 - 300
