Connect Power and Data to 8 PoE-enabled Devices, with 15.4W per Port Output. The IES8100POEGB 8-port 10/100 Mbps Power over Ethernet (PoE) Switch enables you to supply both power and data to up to 8 PoE-capable devices.
The switch complies with 802.3af standards and supplies up to 15.4 W per port - plenty of power for your PoE devices. A flexible solution giving you the freedom to place your equipment in locations where power outlets are not available, this compact PoE Switch features 8 auto-detecting full/half-duplex ports with automatic crossover detection (MDI/MDI-X). A sturdy metal enclosure provides durability in harsh industrial environments.
- StarTech.com 8 Port 10/100 PSE Industrial Power over Ethernet Switch - switch - 8 ports - rack-mountable
- Switch - 8 ports
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE)
- Power Over Ethernet (PoE)
- PoE
- Power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
- 26.6 cm x 16 cm x 4.4 m
- 1.4 kg
- Black
- Localisation
- United Kingdom
- 2-year warranty
- Switch - 8 ports
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE)
- PoE
- RAM
- 512 KB
- Status Indicators
- Power, PoE, link/activity
- 8 x 100Base-TX RJ-45 PoE
- Power Device
- External power adapter
- Black
- UL, FCC, RoHS
- Localisation
- United Kingdom
- 26.6 cm
- 16 cm
- 4.4 m
- 1.4 kg
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 95%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
