StarTech.com 8" Mini HDMI to DVI adapter
Quicklinx: BBD9WS00 Mfr#: HDCDVIMF8IN
£9.11 ex VAT
£10.93 inc VAT
Need to connect your Mini HDMI equipped laptop or tablet to a DVI-D digital display? This 8in Mini HDMI to DVI adapter provides the perfect solution.
  • High-resolution 1920x1200 video support
    Connect your Mini HDMI capable laptop or tablet to a DVI digital monitor, TV or projector, and share your presentations, pictures and videos. Simply plug in male-to-male DVI-D cable, into the adapter and connect the adapter to your device. Perfect for use in a boardroom, your home office or when traveling for work, you can be ready to connect wherever you are.
  • 8-inch cable reduces port damage
    Reduce stress and prevent damage on the device port. The 8-inch cable design reduces the strain on the port as well as the connectors, plus it doesn't block other open ports, leaving them open for connecting other devices.
  • Compact and lightweight design
    The adapter fits nicely inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory to keep in your carry-on baggage. Arrive prepared when presenting to a potential client, teaching offsite, or traveling to a customer location.
StarTech.com 8in Mini HDMI to DVI-D Adapter M/F - 8 inch Mini HDMI to DVI Cable - Connect a Mini HDMI tablet or laptop to a DVI-D display (HDCDVIMF8IN) - video adapter - HDMI / DVI - 20.32 cm
Cable
Video adapter - HDMI / DVI
Double shielded
American Wire Gauge (AWG)
30/32
Length
20.32 cm
Connector
DVI-D - female
Connector (Second End)
Mini HDMI - male
Cable Type
Video adapter
Interface Supported
HDMI / DVI
Double shielded
30/32
Jacket Material
PVC
Shielding Material
Length
20.32 cm
Plated Connector
Gold
Connector
24+1 pin digital DVI - female
19 pin mini HDMI Type C - male
RoHS
Limited warranty - lifetime
Price Range Ex VAT: 0 - 50
