Quicklinx: BVV7WS00 Mfr#: UUUSBOTG8IN
Length: 20.32cm
More than 50 in stock
£4.28 ex VAT
£5.13 inc VAT
Connect your USB On-the-Go capable tablet or phone to an external drive or other USB 2.0 device. Now, you can download confidential information from your smartphone or tablet to an external drive, without having to use a Wi-Fi or mobile data connection. This 8 in. USB OTG cable gives you the perfect solution for backing up your important research and other data collected while you're on the road.
The cable turns the Micro-USB port on your mobile device into a USB OTG host port, so that you can connect a Micro-USB drive or other Micro-USB device, such as a game controller, directly to your phone or tablet.
The OTG cable features a compact design that's perfect for carrying as a tablet accessory.
Please Note: This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device supports USB OTG functionality.
StarTech.com 8in Micro USB to Micro USB Cable - Male to Male - Micro USB OTG Cable for Your Mobile Device (UUUSBOTG8IN) - USB cable - Micro-USB Type B to Micro-USB Type B - 20.32 cm
USB cable
Double shielded
Length
20.32 cm
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
USB On-The-Go
USB cable
Double shielded
Jacket Material
PVC
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
20.32 cm
7 g
Connector
USB On-The-Go, RoHS
BVV7 StarTech.com 5in Micro USB to USB OTG Host Adapter M/F In Stock £5.01
BVV7 StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F In Stock £5.01
BVV7 StarTech.com 8" Micro to Mini USB OTG Cable In Stock £4.28
BVV7 StarTech.com 8" Micro USB OTG Cable In Stock £4.28
Length: 20.32cm
Price Range Ex VAT: 0 - 50
