StarTech.com 7m HDMI to DVI-D Cable - M/M
Quicklinx: 964BWS00 Mfr#: HDDVIMM7M
Length: 7m
£29.09 ex VAT
£34.90 inc VAT
Connect an HDMI -enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display. The HDDVIMM7M 7m HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology. The cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 7m HDMI to DVID Cable M/M - video cable - HDMI / DVI - 7 m
Cable
Video cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
24
Length
7 m
Connector
DVI-D - male
Connector (Second End)
HDMI - male
Moulded
Cable Type
Video cable
Interface Supported
HDMI / DVI
Shielded
24
Jacket Material
PVC
Shielding Material
Length
7 m
Plated Connector
Gold
Moulded
Connector
18+1 pin digital DVI (Single-Link) - male
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
964B StarTech.com 10m HDMI to DVI-D Cable - M/M In Stock £45.03
964B StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £7.82
964B StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.09
964B StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £14.11
964B StarTech.com 15m HDMI to DIV-D Cable – M/M In Stock £77.88
964B StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.20
964B StarTech.com 1.5m HDMI to DVI-D Cable - M/M In Stock £8.45
964B StarTech.com 7m HDMI to DVI-D Cable - M/M In Stock £29.09
Length: 7m
Price Range Ex VAT: 0 - 50
