Connect your VGA monitor with the highest quality connection available, up to 25 ft away from your computer.
The MXTMMHQ7M 7m long VGA cable allows you to connect your VGA monitor or projector at distances of up to 25 feet from your computer, video switch or other VGA device. The high-resolution cable is designed to provide the highest video quality possible through VGA and is ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 7m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 7 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Molded
- Length
- 7 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS, NEC-CMG
- Black
- Limited lifetime warranty
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Molded
- Length
- 7 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS, NEC-CMG
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.07 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £7.06 |
StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M | In Stock | £29.43 |
StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M | In Stock | £47.38 |
StarTech.com 1m Monitor VGA Cable | In Stock | £6.05 |
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £8.25 |
StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £10.46 |
