StarTech.com 7m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Quicklinx: 95QKWS00 Mfr#: MXTMMHQ7M
Length: 7m
22 in stock
£14.58 ex VAT
£17.49 inc VAT
Connect your VGA monitor with the highest quality connection available, up to 25 ft away from your computer.
The MXTMMHQ7M 7m long VGA cable allows you to connect your VGA monitor or projector at distances of up to 25 feet from your computer, video switch or other VGA device. The high-resolution cable is designed to provide the highest video quality possible through VGA and is ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 7m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 7 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
7 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS, NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
7 m
Connector
RoHS, NEC-CMG
95QK StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
95QK StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £23.03
95QK StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £36.43
95QK StarTech.com 1m Monitor VGA Cable In Stock £5.11
95QK StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable - HD15 M/M In Stock £5.22
95QK StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.20
95QK StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £8.05
Length: 7m
Price Range Ex VAT: 0 - 50
