Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, active Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium distance applications such as across-rack network switch or server connections.
- StarTech.com Cisco QSFP-H40G-ACU7M Compatible 7m 40G QSFP+ to QSFP+ DAC Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Active Transceiver Module DAC, 40GE QSFP+ Cable Firepower ASR1000 - Lifetime Warranty (QSFPH40GACU7) - 40GBase direct attach cable - 7 m - black
- 40GBase direct attach cable - SFF-8436
- Technology
- Twinaxial
- Active cable
- Length
- 7 m
- Connector
- QSFP+ - latched
- Connector (Second End)
- QSFP+ - latched
- Black
- OEM Manufacturer Equivalent Part Number
- Cisco QSFP-H40G-ACU7M
- 2-year warranty
- Network Cable Type
- Technology
- Twinaxial
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Impedance
- 100 Ohm
- Active cable
- Length
- 7 m
- 450 g
- Black
- Connector
- QSFP+ - latched
- QSFP+ - latched
- FCC, RoHS, MSA
- 2-year warranty
- 0 °C
- 70 °C
