StarTech.com 7m 23ft 40G QSFP+ AOC Cable
Quicklinx: D9TPWS00 Mfr#: QSFP40GAO7M
Length: 7m
Colour: Black
Hurry, only 2 left in stock!
£265.60 ex VAT
£318.72 inc VAT
Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, active optical cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables, which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections.
StarTech.com MSA Uncoded 7m 40G QSFP+ to QSFP+ AOC Cable - 40 GbE QSFP+ Active Optical Fiber - 40 Gbps QSFP Plus Cable 23' - 40GBase direct attach cable - 7 m - black
40GBase direct attach cable - SFF-8436
Fibre optic
Active cable
Length
7 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Fibre optic
Jacket Material
PVC
Active cable
Length
7 m
450 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
D9TP StarTech.com 10m 33ft 40G QSFP+ AOC Cable In Stock £276.09
D9TP StarTech.com 15m 49ft 40G QSFP+ AOC Cable In Stock £287.29
D9TP StarTech.com 30m 98.4ft 40G QSFP+ AOC Cable In Stock £323.12
D9TP StarTech.com 7m 23ft 40G QSFP+ AOC Cable In Stock £265.60
Length: 7m
Colour: Black
Price Range Ex VAT: 150 - 300
