StarTech.com 7m (23 ft) White CL3 In-wall High Speed HDMI Cable – HDMI to HDMI - M/M
Clearance!
Clearance
Last Few Remaining
Quicklinx: 98DTWS00 Mfr#: HD3MM7MW
Length: 7m
More than 50 in stock
£11.25 ex VAT
£13.50 inc VAT
Run in-wall HDMI cable installations, for applications requiring CL3-rated cables. The HD3MM7MW 7m (22.9ft) High Speed HDMI Cable is CL3-Rated for in-wall installations, and features two gold-plated HDMI (male) connectors to provide a dependable high quality HDMI to HDMI connection between devices such as Blu-Ray Disc players, HDTVs, DVD Players, stereo receivers, projectors and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, StarTech.com HDMI cables can support bandwidth up to 340 MHz (10.2 Gbps) and display resolutions of up to 1440p.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com 7m White CL3 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k - HDMI cable - 7 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
30/32
Length
7 m
White
Connector
HDMI - male
Connector (Second End)
HDMI - male
CL3 rated jacket, in wall mounting
Cable Type
HDMI cable
Double shielded
30/32
Jacket Material
PVC
Shielding Material
Length
7 m
Plated Connector
Gold
White
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Length: 7m
Price Range Ex VAT: 0 - 50
