This 75ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com Coax High Resolution VGA Monitor Cable - VGA extension cable - 22.9 m
- Technology
- Coaxial
- Molded, ferrite bead
- Length
- 22.9 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- HD-15 (VGA) - female
- FCC
- Black
- Limited lifetime warranty
- Technology
- Coaxial
- Length
- 22.9 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- FCC
