Add 7 external, USB 3.0 ports to a computer from a single USB connection. The ST7300USB3B USB 3.0 Hub lets you add seven external USB 3.0 ports to a computer from a single USB 3.0 host connection.
Offering data transfer rates up to 5 Gbps, the USB hub meets SuperSpeed USB 3.0 specifications and is backward compatible with USB 2.0 and 1.x devices.
Designed for easy port access when connecting or disconnecting devices, the hub features one-sided port orientation, with current overload detection and protection across all seven ports. The hub supports Plug-and-Play and Hot-Swap technologies, letting you switch and operate your connected devices without having to power down the host computer.
The USB hub is bus powered for use in environments where a power outlet may be unavailable, but is perfect for high-power USB devices when used with the included optional power adapter.
- StarTech.com 7 Port USB 3.0 Hub – Up To 5 Gbps – 7 x USB – Universal Multi Port USB Extender for Your Desktop – USB Powered (ST7300USB3B) - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- 20.9 cm x 10.5 cm x 3.5 cm
- 140 g
- Black
- System Requirements
- Apple MacOS X 10.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits)
- 2-year warranty
- Hub - 7 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Status Indicators
- Power
- 7 x USB 3.0 Type A , 1 x USB 3.0 Type B
- Power Device
- External power adapter
- Black
- Plug and Play, FCC, RoHS
- OS Required
- 20.9 cm
- 10.5 cm
- 3.5 cm
- 140 g
- Limited warranty - 2 years
- -2 °C
- 52 °C
- 5 - 95%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 56 °C
StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £7.51 |
StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £4.72 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £73.16 |
StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £5.08 |
StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £29.85 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £23.89 |
StarTech.com 3m USB 3.0 Active Extension Cable - M/F | In Stock | £55.50 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £57.89 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £30.13 |
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power | In Stock | £41.11 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £44.80 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power | In Stock | £21.21 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £37.70 |
