StarTech.com 7 Port Dedicated USB Charging Station (5 x 1A 2 x 2A) - Multi-Port USB Charger
Quicklinx: 95QXWS00 Mfr#: ST7CU35122
Set up an external 7 port USB charging station for your tablets, smartphones and other mobile devices. This USB charging station lets you set up an external, 7-port dedicated station for charging tablets, smartphones and other mobile devices.
This station is a standalone device that provides 5 x 1A and 2 x 2A USB charging ports, enabling you to charge multiple devices simultaneously. Support for USB Battery Charging Specification 1.2 lets you charge most mobile devices, including the Apple iPhone, iPad, Microsoft Surface, Samsung Galaxy Tab and more.
The charge station is a perfect solution for charging your mobile devices during meetings in boardrooms, conference rooms, or lobbies. It gives you and your colleagues vital charging access when it's needed most. Plus, consolidating your USB devices onto a single multi-port USB charger offers a more energy-efficient solution and avoids the need for multiple wall outlets or power bars, saving valuable space.
The compact, metal enclosure provides maximum durability and offers an integrated on/off power button for simple operation. For added flexibility, the charge station includes a bracket for wall-mounted installations.
StarTech.com 7 Port Dedicated USB Charging Station (5x 1A, 2x 2A) power adapter - USB
Power adapter
4.5 cm x 11 cm x 2.4 cm
125 g
Output Connector Type
Total 7: USB
AC 100/240 V
P/N: SVA12M5NA, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Power adapter
Tablet, mobile phone
4.5 cm
11 cm
2.4 cm
125 g
AC 100/240 V
Input Connectors
Input Connectors Qty
1
Output connectors
Total 7: 4 pin USB Type A
FCC, RoHS
95QX StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £44.71
95QX StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.34
95QX StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.47
95QX StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £10.90
