Set up an external 7 port USB charging station for your tablets, smartphones and other mobile devices. This USB charging station lets you set up an external, 7-port dedicated station for charging tablets, smartphones and other mobile devices.
This station is a standalone device that provides 5 x 1A and 2 x 2A USB charging ports, enabling you to charge multiple devices simultaneously. Support for USB Battery Charging Specification 1.2 lets you charge most mobile devices, including the Apple iPhone, iPad, Microsoft Surface, Samsung Galaxy Tab and more.
The charge station is a perfect solution for charging your mobile devices during meetings in boardrooms, conference rooms, or lobbies. It gives you and your colleagues vital charging access when it's needed most. Plus, consolidating your USB devices onto a single multi-port USB charger offers a more energy-efficient solution and avoids the need for multiple wall outlets or power bars, saving valuable space.
The compact, metal enclosure provides maximum durability and offers an integrated on/off power button for simple operation. For added flexibility, the charge station includes a bracket for wall-mounted installations.
- StarTech.com 7 Port Dedicated USB Charging Station (5x 1A, 2x 2A) power adapter - USB
- Product Type
- Power adapter
- 4.5 cm x 11 cm x 2.4 cm
- 125 g
- Output Connector Type
- Total 7: USB
- Voltage Required
- AC 100/240 V
- 2-year warranty
- Designed For
- P/N: SVA12M5NA, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- 4.5 cm
- 11 cm
- 2.4 cm
- 125 g
- Voltage Required
- AC 100/240 V
- Input Connectors
- Power
- Input Connectors Qty
- 1
- Output connectors
- Total 7: 4 pin USB Type A
- FCC, RoHS
- Limited warranty - 2 years
- Designed For
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £44.71 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.34 |
StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.47 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £10.90 |
