Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high performance - an excellent choice for Power over Ethernet (PoE) applications. Plus cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options.
All of the cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat 6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
- StarTech.com 7 ft Blue Cat6a / Cat 6a Shielded Patch Cable 7ft - patch cable - 2.1 m - blue
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Wiring Scheme
- T568B
- Shielding Material
- Aluminium-polyester foil
- Molded
- Length
- 2.1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Molded
- Length
- 2.1 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- UL 444, RoHS - up to 500 MHz
