StarTech.com 7 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
Quicklinx: 7NX3WS00 Mfr#: C6ASPAT7BL
Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high performance - an excellent choice for Power over Ethernet (PoE) applications. Plus cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options.
All of the cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat 6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
StarTech.com 7ft CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (C6ASPAT7BL) - patch cable - 2.1 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wiring Scheme
T568B
Shielding Material
Aluminium-polyester foil
Molded
Length
2.1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Wiring Scheme
T568B
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Molded
Length
2.1 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL 444, RoHS - up to 500 MHz
