StarTech.com 7 ft Cat 6 Yellow Molded Gigabit Crossover RJ45 UTP Cat6 Patch Cable
Quicklinx: 76LSWS00 Mfr#: C6CROSS7YL
StarTech.com's yellow Category 6 cables are the perfect way to connect your workspace's emerging gigabit networks. Category 6 cables improve upon the Category 5e specification by providing twice the available bandwidth (up to 250 Mhz), and signal-to-noise margin improvement that is sixteen times (12 dB) better than that provided by Cat 5e. This crossover cable allows you to directly connect two computers together or connect two hubs/switches.
All of StarTech.com's Cat 6 cables are constructed with only top quality components that meet StarTech.com's strict standards for reliability.
StarTech.com Molded Cat6 Crossover UTP Patch Cable - crossover cable - 2.1 m - yellow
Crossover cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
2.1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
2.1 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
UL
60 °C
