StarTech.com's yellow Category 6 cables are the perfect way to connect your workspace's emerging gigabit networks. Category 6 cables improve upon the Category 5e specification by providing twice the available bandwidth (up to 250 Mhz), and signal-to-noise margin improvement that is sixteen times (12 dB) better than that provided by Cat 5e. This crossover cable allows you to directly connect two computers together or connect two hubs/switches.
All of StarTech.com's Cat 6 cables are constructed with only top quality components that meet StarTech.com's strict standards for reliability.
- StarTech.com Molded Cat6 Crossover UTP Patch Cable - crossover cable - 2.1 m - yellow
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded
- Length
- 2.1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded
- Length
- 2.1 m
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- UL
- 60 °C
