StarTech.com 6U Wall-Mount Rack Cabinet
Quicklinx: CZD4WS00 Mfr#: RK616WALM
Depth (mm): 45cm
Width (mm): 60cm
16 in stock
£112.43 ex VAT
£134.91 inc VAT
This 6U server rack cabinet lets you mount your EIA-310 compliant equipment to the wall. The enclosure features a mounting depth up to 16.9 in. and offers a maximum load capacity of 200 lb. (90 kg).
Save valuable floor space, by wall-mounting the enclosure. The wall-mounted design makes this enclosure the ideal solution for optimizing equipment storage in your classroom, retail store, server room or office. This rack also includes a 1U shelf that gives you a stable surface for storing your tools or placing equipment that's not rack-mountable.
The wall-mount network rack makes it easy to install your equipment, with 2-post mounting rails that can be positioned to create more room at the front or the back of the enclosure depending on your requirements.
The 6U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure. The wall-mount server rack also includes all of the cage nuts and mounting screws you'll need to fill the rack with equipment, saving you the time, hassle and cost of sourcing mounting hardware.
For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails.
To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow.
For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
StarTech.com 2 Post 6U 19" Wall Mount Network Cabinet 15" Deep - Locking Vented IT Data Equipment/Switch Rack Enclosure w/Shelf/Hook&Loop rack enclosure cabinet - 6U
Rack enclosure cabinet
Placing / Mounting
Wall mountable
Package Content
2 side panel keys, 2 door keys, 24 screws (12-24), roll of hook-and-loop fastener, 24 cage nuts (12-24)
Height (Rack Units)
6U
Product Material
Steel
60 cm x 45 cm x 37 cm
14 kg
Lockable front door, key lock, adjustable depth, hinged, mesh front door
5-year warranty
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Height (Rack Units)
6U
60 cm
45 cm
37 cm
14 kg
Inner Dimensions
45 cm x 43 cm x 26.7 cm
Weight Limit
90 kg
Limited warranty - 5 years
CZD4 StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £67.96
Depth (mm): 45cm
Width (mm): 60cm
Price Range Ex VAT: 100 - 150
