Improve the organization and appearance of your rack while maintaining airflow. You can improve the appearance and airflow of any standard 19-inch server rack while still enjoying easy access to unused space, using this 6U hinged blanking panel. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room.
The blanking panel features a vented design enabling unobstructed airflow through your rack. The vented panel maximizes airflow to help ensure your equipment is running at an optimal temperature.
With a hinged design, you can quickly open the blanking panel, make your required adjustments and when you're finished, simply close the panel to restore the professional appearance and order of your server room. The panel is reversible, so you to install it on the left or the right side of your rack, to best suit your needs. The rack panel also comes complete with rack installation screws and nuts, giving you everything you need to ensure a hassle-free installation.
- StarTech.com 6U Hinged Blanking Panel - Vented 19inch Server Rack Panel - Tool-less Installation - TAA Compliant Filler Panel (RKPNLHV6U) - rack blanking panel - 6U
- Product Type
- Rack blanking panel
- Package Content
- 4 screws (10-32), 4 nuts (10-32)
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 6U
- 48.3 cm x 1.5 cm x 26.5 cm
- 839 g
- Vented
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30
- Product Type
- Package Content
- Rack Size
- 19"
- 6U
- 48.3 cm
- 1.5 cm
- 26.5 cm
- 839 g
- Black
- Vented
- EIA-310-D, RoHS
- Limited warranty: - 2 years
- Designed For
