StarTech.com 6U 22" Wall Mount Server Rack
Quicklinx: 8G5JWS00 Mfr#: RK619WALLOH
Depth (mm): 55.5cm
Type: Wall Mount
U Height: 6U
Width (mm): 60.4cm
Hurry, only 1 left in stock!
£183.40 ex VAT
£220.08 inc VAT
Wall-mount your server or networking equipment with a hinged rack design for easy access and maintenance. The RK619WALLOH 6U 22in Depth Hinged Open Frame Wall Mount Server Rack lets you wall mount your (19-inch wide) servers, A/V or network equipment and features a hinged rack design that allows the entire frame to swing open for easy installation and maintenance of your equipment.
The 6U wallmount rack offers a 4 post design for additional support of your equipment, storing a maximum weight capacity of 63 kg (140 lbs). Constructed of high-quality SPCC cold-rolled steel for strength and durability, the open frame wallmount server rack allows for maximum airflow, and ships complete with all of the rack screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com 6U Hinged Open Frame Wall Mount Network Rack - 4-Post 22" Depth Swing Out Computer Equipment Rack - 110lbs capacity (RK619WALLOH) rack - 6U
Rack
Placing / Mounting
Wall mountable
Rack Size
22"
Height (Rack Units)
6U
Product Material
Cold-rolled steel
60.4 cm x 55.5 cm x 40.8 cm
13.9 kg
Hinged
Rack
Placing / Mounting
Wall mountable
Product Material
Cold-rolled steel
Rack Size
22"
Height (Rack Units)
6U
60.4 cm
55.5 cm
40.8 cm
13.9 kg
Weight Limit
49.8 kg
Mounting Kit
Included
Hinged
EIA-310-D, UL, RoHS
Limited warranty - lifetime
8G5J StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £100.89
8G5J StarTech.com 12U 19in Wall Mount Side Mount Open Frame Rack Cabinet In Stock £261.27
8G5J StarTech.com 8U 19in Wall Mount Side Mount Open Frame Rack Cabinet In Stock £269.27
8G5J StarTech.com 6U 22" Wall Mount Server Rack In Stock £183.40
Depth (mm): 55.5cm
Type: Wall Mount
U Height: 6U
Width (mm): 60.4cm
Price Range Ex VAT: 150 - 300
