StarTech.com 6m 20ft 10G SFP+ DAC Cable
Quicklinx: D9VTWS00 Mfr#: SFPH10GBCU6M
Connect your Cisco 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting applications such as point-to-point in-rack and across-rack network switch or server connections.
StarTech.com Cisco SFP-H10GB-CU6M Compatible 6m 10G SFP+ to SFP+ DAC Twinax, 10GbE SFP+ Copper DAC 10Gbps/10GE Low Power Passive SFP+ Transceiver Module DAC Cable, Cisco Firepower ASR9000 - Lifetime Warranty (SFPH10GBCU6M) - 10GBase direct attach cable - 6 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
6 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
6 m
380 g
Connector
SFP+ - latched
SFP+ - latched
FCC, RoHS, MSA
70 °C
