StarTech.com 6in USB 3.0 Extension Cable
Quicklinx: B2WHWS00 Mfr#: USB3EXT6INBK
Length: 15.2cm
More than 50 in stock
£4.11 ex VAT
£4.93 inc VAT
Extend the reach of your USB 3.0 port by 6 inches. The USB3EXT6INBK USB 3.0 extension cable extends the reach of a USB 3.0 port on your laptop or desktop computer by 6 inches and gives you more room for connecting multiple devices.
The cable can also help to prevent damage to the USB 3.0 port on your computer in testing environments or other situations where the port is accessed repeatedly.
The extension allows you to connect multiple devices at once, such as flash drives, and gives you open access to ports, even when they are located closely together.
The cable can also be used as a port saver in busy environments where cables are unplugged and re-inserted frequently.
StarTech.com 6in Short USB 3.0 Extension Adapter Cable (USB-A Male to USB-A Female) - USB 3.1 Gen 1 (5Gbps) Port Saver Cable - Black (USB3EXT6INBK) - USB extension cable - 15.2 cm
USB extension cable
Molded
Length
15.2 cm
Connector
9 pin USB Type A - female
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: 35FCREADBU3, HB30A4AIB, HB30C4AIB, HB31C4AB, SU2DUPERA11, USB3SAA3MBK
USB extension cable
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Molded
Length
15.2 cm
Connector
USB 3.0, RoHS
B2WH StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.15
B2WH StarTech.com 6 ft Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.15
B2WH StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £5.77
B2WH StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £5.77
B2WH StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £9.03
B2WH StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.15
B2WH StarTech.com 6in USB 3.0 Extension Cable In Stock £4.11
Length: 15.2cm
Price Range Ex VAT: 0 - 50
