StarTech.com 6in USB 3.0 Extension Cable
Quicklinx: B2WHWS00 Mfr#: USB3EXT6INBK
Length: 15.2cm
More than 50 in stock
£4.05 ex VAT
£4.86 inc VAT
Extend the reach of your USB 3.0 port by 6 inches. The USB3EXT6INBK USB 3.0 extension cable extends the reach of a USB 3.0 port on your laptop or desktop computer by 6 inches and gives you more room for connecting multiple devices.
The cable can also help to prevent damage to the USB 3.0 port on your computer in testing environments or other situations where the port is accessed repeatedly.
The extension allows you to connect multiple devices at once, such as flash drives, and gives you open access to ports, even when they are located closely together.
The cable can also be used as a port saver in busy environments where cables are unplugged and re-inserted frequently.
StarTech.com 6in Black USB 3.0 Extension Adapter Cable A to A - M/F - USB extension cable - 15.2 cm
USB extension cable
Molded
Length
15.2 cm
Connector
9 pin USB Type A - female
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: 35FCREADBU3
USB extension cable
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Molded
Length
15.2 cm
Connector
USB 3.0, RoHS
P/N: 35FCREADBU3
Length: 15.2cm
Price Range Ex VAT: 0 - 50
