StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M
Quicklinx: 8D5DWS00 Mfr#: SLSATAADAP6
Length: 15.24cm
Type: SATA
13 In Stock
£9.28 ex VAT
£11.13 inc VAT
Connect a Slimline SATA optical drive up to 6in away from a standard SATA motherboard connection. The SLSATAADAP6 Slimline SATA to SATA adapter features a Slimline Serial ATA connector on one end and a standard SATA data connector (with SATA power connector) on the other, enabling you to connect a Slimline SATA optical drive to standard motherboard and power supply connections.
The slim SATA adapter offers 6-inches in cable length, which compared to standard (non-cable) SATA/Slimline SATA adapter reduces strain off the drive connector and allows for flexible cable routing when positioning the Slimline SATA drive within the system case.
StarTech.com 6in Slimline SATA to SATA Adapter with Power - Slim SATA (F) to SATA (M) - Slimline Serial ATA to SATA (SLSATAADAP6) - SATA adapter
SATA adapter
Interface Speed
Serial ATA 150/300/600
Connector
13 pin Slimline Serial ATA - female
Connector (Second End)
22 pin Serial ATA - male
Red
Storage Cable Type
SATA adapter
Interface Speed
American Wire Gauge (AWG)
18
Red
Connector
RoHS
8D5D StarTech.com 6in Slimline SATA to SATA Adapter with Power - F/M In Stock £9.28
Length: 15.24cm
Type: SATA
