StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter
Quicklinx: 839YWS00 Mfr#: SATPCIEX8ADP
£5.42 ex VAT
£6.50 inc VAT
Convert two 15-pin SATA power supply connectors to an 8-pin PCI Express video card power connector. The SATPCIEX8ADP SATA to PCI Express Video Card Power Adapter Cable features an 8-pin PCI Express (female) power connector as well as two 15-pin SATA (male) power connectors, providing a cost-effective way to connect a PCIe video card to Serial ATA power connectors provided by the computer power supply - eliminating the need to upgrade the power supply for the sake of video card compatibility.
StarTech.com 6in SATA Power to 8 Pin PCI Express Video Card Power Cable Adapter - SATA to 8 pin PCIe power - power cable - SATA power to 8 pin PCIe power - 15 cm
Power cable
Length
15 cm
Connector
2 x 15 pin Serial ATA power - male
Connector (Second End)
8 pin PCI Express power - male
Power cable
American Wire Gauge (AWG)
18
Plated Connector
Gold
Length
15 cm
Connector
